Nastavení
1 CONNECTION TO PC
following section.
the following URL:
2 CONNECTION WITH THE UNIT
If the unit is not configured yet (e.g. a new unit) it is advised to not connect
any servos yet.
installation process.
directory.
with the file „settings.sh“.
4 CONFIGURATION SOFTWARE
PROBLEMS WITH WINDOWS
manager.
5 SOFTWARE USAGE
5.1 CONNECTION TAB
Swashplate
PWM – standard receiver.
PPM – single line connection.
Flight style
requirements of the pilot.
Channels
channel to each function.
(See chapter 5.6).
as well.
- N – Normal (Rate)
- HL – Head Lock
SPECTRUM ANALYSER
- X - elevator axis
- Y - aileron axis
- Z - rudder axis
- Stop the motor.
Cyclic servos reverse
tail blow outs may occur.
- Head-Lock mode: 1% to 100%
- ESC with RPM output
- ESC without RPM output
- Magnetic sensor
- Governor Response: 5
- Holding Performance: 1
| Shortcut | Function |
