Connexion Spektrum PWM
Revision as of 16:40, 20 November 2017 by GoblinShefford (Talk | contribs) (Created page with "Câblage PWM")
Ce tableau décrit la connexion du récepteur Spektrum AR610. Parce que les étiquettes sont les mêmes entre les autres récepteurs, vous pouvez également l'utiliser pour d'autres récepteurs AR.
Câblage PWM
UNIT RECEIVER
RUD RUDD
AUX GEAR
ELE/PIT/AIL ORANGE wire to AILE
RED wire to AUX 1
BROWN wire to ELEV
Info.png Servo connectors are connected always with Orange wire closer to the labels (in the receiver and unit as well).
Info.png Special cable which ends with 3 servo connectors must be connected in the way, that these wires are always closer to the port labels.
  • ESC should be connected to the THRO port.
  • If External BEC is used, you can connect it to a free port in the receiver.
