Вывод оборотов с CC Phoenix Edge.
Revision as of 07:29, 16 October 2018 by Gstatopen (Talk | contribs) (Created page with "Регуляторы Castle Creations Phoenix имеют вывод со встроенного датчика оборотов. Остается только подключ...")
Регуляторы Castle Creations Phoenix имеют вывод со встроенного датчика оборотов. Остается только подключить этот провод и отключить встроенный гувернер.
1 Required modification
For usage with the Spirit units a small modification of the RPM cable is needed.
  • Move the White cable to the middle in the Servo connector.
  • You can do so with a needle easily.
Wire layout
White wire: RPM Output Signal (PIT pin)
Yellow wire: Throttle signal (AUX1 port)
Red wire: BEC Voltage (AUX1 port)
Brown wire: Ground (AUX1 port)
2 Changing ESC settings
It is very important to change ESC mode so that internal Governor is disabled. This can be done by Castle Link software.
3 Governor Settings
  • Throttle Frequency: 60Hz.
