Подключение Spektrum PWM
Revision as of 10:38, 16 October 2018 by Gstatopen (Talk | contribs) (Created page with "Оранжевый провод к AILE")
Эта таблица описывает соединения приемника Spektrum AR610. Поскольку обозначения едины, вы можете использовать таблицу и для других приемников.
Подключение PWM
Модуль Приемник
RUD RUDD
AUX GEAR
ELE/PIT/AIL Оранжевый провод к AILE
RED wire to AUX 1
BROWN wire to ELEV
Info.png Servo connectors are connected always with Orange wire closer to the labels (in the receiver and unit as well).
Info.png Special cable which ends with 3 servo connectors must be connected in the way, that these wires are always closer to the port labels.
  • ESC should be connected to the THRO port.
  • If External BEC is used, you can connect it to a free port in the receiver.
