Подключение Spektrum PWM
Revision as of 10:38, 16 October 2018 by Gstatopen (Talk | contribs) (Created page with "Коричневый провод к ELEV")
Эта таблица описывает соединения приемника Spektrum AR610. Поскольку обозначения едины, вы можете использовать таблицу и для других приемников.
Подключение PWM
| Модуль | Приемник |
| RUD | RUDD |
| AUX | GEAR |
| ELE/PIT/AIL | Оранжевый провод к AILE Красный провод к AUX1 Коричневый провод к ELEV |
Servo connectors are connected always with Orange wire closer to the labels (in the receiver and unit as well).
Special cable which ends with 3 servo connectors must be connected in the way, that these wires are always closer to the port labels.
- ESC should be connected to the THRO port.
- If External BEC is used, you can connect it to a free port in the receiver.
