Spektrum Integration
Revision as of 20:46, 30 January 2020 by Admin (Talk | contribs)
Spektrum integration is available for all the latest telemetry enabled Spektrum receivers!
This mean you can fully configure Spirit units with Spektrum transmitters in real-time without need of a computer.
1 Requirements
  • Spektrum transmitter: DX6e, DX6 Gen 2, DX6 Gen 3, DX7 Gen 2, DX8 Gen 2, DX9, DX10T, DX18 Gen 1, DX18 Gen 2, DX18T, DX18QQ, DX20, IX12, IX20
  • Serial Telemetry receiver: SPM4649T, SPM4650, SPM4651, SPM9747, AR6610T.
  • Cable - depending on your receiver.
2 Receiver
Currently there are two different options.
  • SPM4649T receiver - solution compatible with older Spektrum satellites
  • SRXL2 receivers - recommended for new builds
Please note you can use SRXL2 receiver only together with other SRXL2 satellites.
2.1 SPM4649T receiver
2.2 SRXL2 receivers
3 Transmitter preparation
3.1 Firmware update
  • DX6e does not need update (version 1.00 will work).
3.2 Configuration
Configure:
  • 1: ESC
  • 2: Text Gen
  • 3: Flight Pack mAh
4 Integration Menu
4.1 Entering the menu
4.2 Closing the menu
4.3 Navigation
Info.png To navigate in the menu you can use Aileron and Elevator sticks.
  • Aileron Left - Back in the menu; Stop edit of a parameter' value.
  • Aileron Right - Enter a Submenu; Edit selected parameter.
  • Elevator Up - Go up in the menu or submenu; Increase value of selected parameter.
  • Elevator Down - Go down in the menu or submenu; Decrease value of selected parameter.
5 Telemetry data
5.1 Displaying the data
  • Capacity [mAh] - ESC Telemetry | Main Battery consumed capacity
6 Troubleshooting
6.1 SPM4649T always in binding mode
