Spektrum Integration
Spektrum integration is available for all the latest telemetry enabled Spektrum receivers!
This mean you can fully configure Spirit units with Spektrum transmitters in real-time without need of a computer.
1 Requirements
- Spektrum transmitter: DX6e, DX6 Gen 2, DX6 Gen 3, DX7 Gen 2, DX8 Gen 2, DX9, DX10T, DX18 Gen 1, DX18 Gen 2, DX18T, DX18QQ, DX20, IX12, IX20
- Serial Telemetry receiver: SPM4649T, SPM4650, SPM4651, SPM9747, AR6610T.
- Cable - depending on your receiver (see Wiring section).
2 Receiver Wiring
Currently there are two different options.
Please note you can use SRXL2 receiver only together with other SRXL2 satellites.
2.1 SPM4649T Receiver Wiring
2.2 SRXL2 Receiver Wiring
3 Transmitter preparation
3.1 Firmware update
3.2 Configuration
Configure:
- 1: ESC
- 2: Text Gen
- 3: Flight Pack mAh
4 Integration Menu
To navigate in the menu you can use Aileron and Elevator sticks.
5 Telemetry data
5.1 Displaying the data
- Capacity [mAh] - ESC Telemetry | Main Battery consumed capacity
6 Troubleshooting
6.1 SPM4649T always in binding mode
