Konfiguration
Revision as of 09:34, 19 September 2016 by Spiritdm (Talk | contribs) (Created page with "Querachse")
1 ANSCHLUSS AN EINEN COMPUTER
2 ANSCHLUSS AN DIE EINHEIT
ACHTUNG
4 KONFIGURATIONSSOFTWARE
ACHTUNG
PROBLEME UNTER WINDOWS
5 SOFTWARE VERWENDUNG
5.2 GENERAL (Allgemein)
ACHTUNG
Swashplate (Taumelscheibe)
Receiver (Empfänger)
PWM – Standardempfänger.
Flight style
Channels (Kanäle)
Echtzeit - Tuning
ACHTUNG
ACHTUNG
  • N – Normal (Rate)
  • HL – Head Lock
  • X - Querachse
  • Y - aileron axis
  • Z - rudder axis
  8. Stop the motor.
Fa.png Good Health Message:
I.png Calibration Finished:
I.png Governor was Engaged:
Zv.png Cyclic Ring Activated:
Zv.png Rudder Limit Reached:
Tr.png Receiver Signal Lost:
Tr.png Power Voltage is low:
Cyclic servos reverse
  • Head-Lock mode: 1% to 100%
WARNING
  • ESC with RPM output
  • ESC without RPM output
