Konfiguration
Revision as of 08:20, 19 September 2016 by Spiritdm (Talk | contribs) (Created page with "Links / Rechts limit")
1 ANSCHLUSS AN EINEN COMPUTER
2 ANSCHLUSS AN DIE EINHEIT
ACHTUNG
4 KONFIGURATIONSSOFTWARE
ACHTUNG
PROBLEME UNTER WINDOWS
5 SOFTWARE VERWENDUNG
5.2 GENERAL (Allgemein)
ACHTUNG
Swashplate (Taumelscheibe)
Receiver (Empfänger)
PWM – Standardempfänger.
Flight style
Channels (Kanäle)
Echtzeit - Tuning
ACHTUNG
ACHTUNG
  • N – Normal (Rate)
  • HL – Head Lock
  • X - Querachse
  • Y - Längsachse
  • Z - Hochachse
  • In-Flight - Spektrum-Player
Vibrationsniveau:
Messvorgang
  8. Halten Sie den Motor
Erkennen von Vibrationen
HINWEIS
5.4 SERVOS TAB (Servos)
Typ
HINWEIS
5.5 LIMITS TAB (Begrenzungen)
ACHTUNG
Links / Rechts limit - Sets the minimum and maximum deflection of rudder rotor blades. We recommend setting these values for both directions to the maximum allowed range by the manufacturer of the helicopter. Otherwise, the rudder may not be able to keep the yaw direction during demanding maneuvers and tail blow outs may occur. Do not exceed allowed limit for your model.
  • Head-Lock mode: 1% to 100%
WARNING
  • ESC with RPM output
  • ESC without RPM output
