Spektrum PWM kapcsolat
Revision as of 19:23, 27 August 2020 by PSzakra (Talk | contribs) (Created page with "Ez a táblázat a Spektrum AR610 vevő csatlakoztatását írja le. Mivel a címkék azonosak a többi vevőkészülék között, használhatják más AR vevőkhöz is.")
PWM Wiring
| UNIT | RECEIVER |
| RUD | RUDD |
| AUX | GEAR |
| ELE/PIT/AIL | ORANGE wire to AILE RED wire to AUX 1 BROWN wire to ELEV |
Servo connectors are connected always with Orange wire closer to the labels (in the receiver and unit as well).
Special cable which ends with 3 servo connectors must be connected in the way, that these wires are always closer to the port labels.
- ESC should be connected to the THRO port.
- If External BEC is used, you can connect it to a free port in the receiver.
