Spektrum PWM kapcsolat
Revision as of 21:24, 27 August 2020 by PSzakra (Talk | contribs) (Created page with "Egység")
Ez a táblázat a Spektrum AR610 vevő csatlakoztatását írja le. Mivel a címkék azonosak a többi vevőkészülék között, használhatják más AR vevőkhöz is.
PWM Bekötés
Egység RECEIVER
RUD RUDD
AUX GEAR
ELE/PIT/AIL ORANGE wire to AILE
RED wire to AUX 1
BROWN wire to ELEV
Info.png Servo connectors are connected always with Orange wire closer to the labels (in the receiver and unit as well).
Info.png Special cable which ends with 3 servo connectors must be connected in the way, that these wires are always closer to the port labels.
  • ESC should be connected to the THRO port.
  • If External BEC is used, you can connect it to a free port in the receiver.
