Spektrum PWM kapcsolat
Revision as of 21:25, 27 August 2020 by PSzakra (Talk | contribs) (Created page with "Barna a MAGASSÁGI-ba")
Ez a táblázat a Spektrum AR610 vevő csatlakoztatását írja le. Mivel a címkék azonosak a többi vevőkészülék között, használhatják más AR vevőkhöz is.
PWM Bekötés
| Egység | VEVŐ |
| RUD | RUDD |
| AUX | GEAR |
| ELE/PIT/AIL | Narancs vezeték a CSŰRŐ-be PIROS vezeték az AUx1 -be Barna a MAGASSÁGI-ba |
Servo connectors are connected always with Orange wire closer to the labels (in the receiver and unit as well).
Special cable which ends with 3 servo connectors must be connected in the way, that these wires are always closer to the port labels.
- ESC should be connected to the THRO port.
- If External BEC is used, you can connect it to a free port in the receiver.
