Configuración
Revision as of 10:07, 19 September 2016 by Zexx86 (Talk | contribs) (Created page with "Cuando se asigna un canal para la función del ''Acelerador (Throttle)'', el acelerador de salida de la unidad se puede obtener de la posición AUX. Cuando se asigna un canal...")
1 CONEXION AL PC
Es necesario instalar nada.
2 CONEXION CON LA UNIDAD
NOTA
4 CONFIGURACION SOFTWARE
NOTA
PROBLEMAS CON WINDOWS
5 USO DE SOFTWARE
NOTA
Posicion
Swashplate
PWM – receptor standar.
Channels (Canales)
  • N – Normal (Rate)
  • HL – Head Lock
SPECTRUM ANALYSER
  • X - elevator axis
  • Y - aileron axis
  • Z - rudder axis
  8. Stop the motor.
Fa.png Good Health Message:
I.png Calibration Finished:
I.png Governor was Engaged:
Zv.png Cyclic Ring Activated:
Zv.png Rudder Limit Reached:
Tr.png Receiver Signal Lost:
Tr.png Power Voltage is low:
Cyclic servos reverse
  • Head-Lock mode: 1% to 100%
WARNING
  • ESC with RPM output
  • ESC without RPM output
