YGE ESC RPM
Revision as of 13:31, 14 January 2021 by DaniloB (Talk | contribs) (Created page with "Collegare il filo arancione a terra per il volo, per evitare radiazioni estranee.")
YGE 90 LV
1 cablaggio
1.1 YGE 40, YGE 60
Colori collegamenti
Marrone Terra
rosso Non collegato
arancione RPM-Segnale
Info.png Qui trovi il segnale RPM sul cavo split. È importante collegare anche il cavo marrone per evitare radiazioni estranee.
1.2 YGE 90LV, 120LV, 120LVK
Colori collegamenti
marrone terra
rosso BEC (5,7V/7,4V/8V)
Info.png Qui trovi il segnale RPM sul cavo split (Slave). È importante collegare anche il cavo marrone per evitare radiazioni estranee.
1.3 YGE 60HV, 90HV, 120HV, 160HV, 200HV, 320HV (tutti gli Opzioni senza BEC)
Colori collegamenti
marrone terra
rosso RPM-Segnale
arancione Segnale di programmazione per ProgCard
Info.png Qui trovi l'uscita RPM sul cavo ProgCard corto. È importante collegare anche il cavo marrone per evitare radiazioni estranee.
2 External Governor mode
Warning.png For using external Governor with the YGE controllers, it's important to set the ESC to external governor mode!
  • For our newest models, it's very easy. Just do the mode-setup and select Mode 1 (external Governor). Everything will be set to optimal parameters for use with FBL-governors and no ProgCard is needed.
  • For older ESC's that don't have the mode-setup, a ProgCard is needed.
    • Except for startup speed, program everything as usual.
    • Go to the second page of the ProgCard
    • Set Startup speed to Heli middle and confirm with Enter.
    • Select Gov off. and confirm 3x with Enter.
    • Set Startup speed to plane middle and confirm with Enter. For confirmation you will hear another acknowledge sound as usual.
    • Your ESC is now set to external Governor Mode!
    • After programming, disconnect the main battery, ProgCard and patch cables.
3 Throttle Range
By default YGE controllers are programmed to 1100μs - 1900μs Throttle Range. This is same as the default range of the Spirit. If Throttle was not calibrated yet, you can leave all the settings untouched. Then it will match with no modification.
4 Governor Settings
  • Throttle Frequency: 120Hz.
  • Throttle Range - Min.: 1100 us.
  • Throttle Range - Max.: 1900 us.
