Spektrum PWM connessione
Revision as of 14:57, 14 January 2021 by DaniloB (Talk | contribs) (Created page with "PWM Cablaggio")
Questa tabella descrive il collegamento del ricevitore Spektrum AR610. Poiché le etichette sono le stesse tra gli altri ricevitori, puoi usarlo anche per altri ricevitori AR.
PWM Cablaggio
| UNIT | RECEIVER |
| RUD | RUDD |
| AUX | GEAR |
| ELE/PIT/AIL | ORANGE wire to AILE RED wire to AUX 1 BROWN wire to ELEV |
Servo connectors are connected always with Orange wire closer to the labels (in the receiver and unit as well).
Special cable which ends with 3 servo connectors must be connected in the way, that these wires are always closer to the port labels.
- ESC should be connected to the THRO port.
- If External BEC is used, you can connect it to a free port in the receiver.
