Spektrum PWM connessione
Revision as of 16:58, 14 January 2021 by DaniloB (Talk | contribs) (Created page with "Filo MARRONE a ELEV")
Questa tabella descrive il collegamento del ricevitore Spektrum AR610. Poiché le etichette sono le stesse tra gli altri ricevitori, puoi usarlo anche per altri ricevitori AR.
PWM Cablaggio
UNITA' RECEVENTE
RUD RUDD
AUX GEAR
ELE/PIT/AIL Filo ARANCIONE ad AILE
Filo ROSSO ad AUX 1
Filo MARRONE a ELEV
Info.png Servo connectors are connected always with Orange wire closer to the labels (in the receiver and unit as well).
Info.png Special cable which ends with 3 servo connectors must be connected in the way, that these wires are always closer to the port labels.
  • ESC should be connected to the THRO port.
  • If External BEC is used, you can connect it to a free port in the receiver.
