Spektrum Integration
Revision as of 11:59, 29 November 2021 by FuzzyBot (Talk | contribs) (Importing a new version from external source)
Spektrum integration is available for all the latest telemetry enabled Spektrum receivers!
This mean you can fully configure Spirit units with Spektrum transmitters in real-time without need of a computer.
1 Requirements
  • Spektrum transmitter: DX6e, DX6 Gen 2, DX6 Gen 3, DX7 Gen 2, DX8 Gen 2, DX9, DX10T, DX18 Gen 1, DX18 Gen 2, DX18T, DX18QQ, DX20, IX12, IX20, NX6, NX8, NX10
  • Serial Telemetry receiver: SPM4649T.
  • Jeti Integration cable available in our stores (or own modification of the wires).
2 Receiver Wiring
Currently there are two different options.
  • SPM4649T receiver - solution compatible with older Spektrum satellites
  • SRXL2 receivers - recommended for new builds
Please note you can use SRXL2 receiver only together with other SRXL2 satellites.
2.1 SPM4649T Receiver Wiring
2.2 SRXL2 Receiver Wiring
3 Transmitter preparation
3.1 Firmware update
  • DX6e does not need update (version 1.00 will work).
With the latest Spektrum NX radiso, please make sure to install the latest firmware 3.06, otherwise integration will not work.
3.2 Configuration
Configure:
  • 1: ESC
  • 2: Text Gen
  • 3: Flight Pack mAh
4 Integration Menu
4.1 Entering the menu
4.2 Closing the menu
4.3 Navigation
Info.png To navigate in the menu you can use Aileron and Elevator sticks.
  • Aileron Left - Back in the menu; Stop edit of a parameter' value.
  • Aileron Right - Enter a Submenu; Edit selected parameter.
  • Elevator Up - Go up in the menu or submenu; Increase value of selected parameter.
  • Elevator Down - Go down in the menu or submenu; Decrease value of selected parameter.
5 Telemetry data
5.1 Displaying the data
  • Capacity [mAh] - ESC Telemetry | Main Battery consumed capacity
6 Troubleshooting
6.1 SPM4649T always in binding mode
