Spektrum Integration
Spektrum integration is available for all the latest telemetry enabled Spektrum receivers!
This mean you can fully configure Spirit units with Spektrum transmitters in real-time without need of a computer.
1 Requirements
- Spektrum transmitter: DX6e, DX6 Gen 2, DX6 Gen 3, DX7 Gen 2, DX8 Gen 2, DX9, DX10T, DX18 Gen 1, DX18 Gen 2, DX18T, DX18QQ, DX20, IX12, IX20, NX6, NX8, NX10
- Serial Telemetry receiver: SPM4649T, SPM4650, SPM4651, SPM9747, AR6610T.
- Cable - depending on your receiver (see Wiring section).
2 Receiver Wiring
Currently there are two different options.
Please note you can use SRXL2 receiver only together with other SRXL2 satellites.
2.1 SPM4649T Receiver Wiring
2.2 SRXL2 Receiver Wiring
3 Transmitter preparation
3.1 Firmware update
With the latest Spektrum NX radiso, please make sure to install the latest firmware 3.06, otherwise integration will not work.
3.2 Configuration
Configure:
- 1: ESC
- 2: Text Gen (only for older radio firmware)
- 3: Flight Pack mAh
When adding Text Gen make sure that Display option is configured to Act or Roller (depending on radio). Please note, recent radio update do not require any Text Gen settings. After activating the integration menu, you can view the Text Gen screen by using roller at the Telemetry monitor page.
4 Integration Menu
To navigate in the menu you can use Aileron and Elevator sticks.
5 Telemetry data
5.1 Displaying the data
- Capacity [mAh] - ESC Telemetry | Main Battery consumed capacity
6 Troubleshooting
6.1 SPM4649T always in binding mode
