HobbyWing Telemetry
Revision as of 09:24, 17 November 2023 by Admin (Talk | contribs) (Marked this version for translation)
HobbyWing Platinum V4 ESC has telemetry feature built-in in the Programming port. This allows telemetry data transmission to the unit. To allow the ESC telemetry, it is necessary to have updated ESC firmware to a recent, non VBar firmware.
1 Telemetry Cable
2 Interfacing
3 Spirit Settings
3.1 Telemetry activation
4 Displaying telemetry data
Warning.png Please update your ESC firmware to the most recent firmware, but one which has not "VBar" in the name. Otherwise all telemetry values will be Zero.
5 Supported models
Battery Voltage
Battery Current
Consumed Capacity
ESC Temperature
RPM
Platinum 25A V4 ✔ x x ✔ ✔
Platinum 40A V4 ✔ x x ✔ ✔
Platinum 60A V4 ✔ x x ✔ ✔
Platinum 80A V4 ✔ ✔ ✔ ✔ ✔
Platinum 120A V4 ✔ ✔ ✔ ✔ ✔
Platinum HV 130A V4 ✔ ✔ ✔ ✔ ✔
Platinum HV 130A OPTO V4 ✔ ✔ ✔ ✔ ✔
Platinum HV 160A V4 ✔ ✔ ✔ ✔ ✔
Platinum HV 200A OPTO V4 ✔ ✔ ✔ ✔ ✔
