YGE Telemetry
Revision as of 09:25, 17 November 2023 by Admin (Talk | contribs)
YGE LVT and YGE HVT ESCs have telemetry feature built-in in the Programming port. This allows telemetry data transmission to the unit. To allow the ESC telemetry, it is necessary to have updated ESC as the older firmware versions were not supporting it.
1 Telemetry Cable
To allow the telemetry data transmission the JST-Servo adapter is required. This cable is available in our Eshop.
Warning.png It is very important to modify the cable correctly, otherwise permanent damage of the Spirit unit will occur!
1.1 Cable modification
Extremely important is the following Modification of the JST-Servo adapter cable. It is required to unplug or cut RED wire of the adapter as displayed at the photo.
2 Interfacing
Connect modified JST-Servo adapter to the primary Spektrum satellite port (SAT1) in the unit. Smaller Spirit units will utilize the one native Spektrum satellite port (μSpirit - SAT port).
Servo connector of the JST-Servo adapter cable should be connected with the Blue Servo connector of the YGE ESC.
3 Spirit Settings
3.1 Telemetry activation
Go to the Advanced/Telemetry settings and set the YGE LVT/HVT option.
4 Displaying telemetry data
5 Supported models
Battery Voltage
BEC Voltage
Battery Current
Consumed Capacity
ESC Temperature
RPM
YGE 35LVT ✔ ✔ ✔ ✔ ✔ ✔
YGE 65LVT ✔ ✔ ✔ ✔ ✔ ✔
YGE 95LVT ✔ ✔ ✔ ✔ ✔ ✔
YGE 135LVT ✔ ✔ ✔ ✔ ✔ ✔
YGE 90HVT Opto ✔ ✔ ✔ ✔ ✔ ✔
YGE 120HVT Opto ✔ ✔ ✔ ✔ ✔ ✔
YGE 165HVT Opto ✔ ✔ ✔ ✔ ✔ ✔
YGE 205HVT ✔ ✔ ✔ ✔ ✔ ✔
