OMP Telemetry
Revision as of 06:43, 15 September 2025 by Admin (Talk | contribs)
čeština • ‎Deutsch • ‎English • ‎español • ‎italiano • ‎русский
This guide fits OMP and ZTW ESCs. OMP and ZTW and ESC has telemetry feature built-in in the Programming port. This allows telemetry data transmission to the unit.
Similarly XDFly ESCs have telemetry feature built-in. Additionally they support ESC Integration with Spirit Wave radios. Wiring is slightly different!
For XDFly ESC visit XDFly Telemetry page.
1 Telemetry Cable
To allow the telemetry data transmission the Telem OMP cable is required. This cable is available in our Eshop.
Telem UNI cable can be used too after small modification using a needle.
Warning.png We do not recommend to make this cable at home since improper connection will cause permanent damage of the unit. The Red wire must be disconnected always!
2 Interfacing
Connect the Telemetry cable to the primary Spektrum satellite port (SAT1) in the unit - apply for Spirit 2, Spirit RS, Spirit Pro, Spirit GT, Spirit GTR, Spirit W1.
There is no support for Spirit v1 units.
Servo connector of the Telem OMP cable should be connected to the ESC - programming port. Make sure to connect Orange wire of the Telem OMP cable at the TX pin. Brown pin at the - pin.
XDFly ESC Integration with Wave require to use RX pin of the ESC.
3 Spirit Settings
3.1 Telemetry activation
Go to the Advanced/Telemetry settings and set the OMP M4 option.
4 Displaying telemetry data
5 Supported models
Battery Voltage
Battery Current
Consumed Capacity
ESC Temperature
RPM
OMP M4 ✔ ✔ ✔ ✔ ✔
