XDFly Telemetry
Revision as of 08:54, 15 September 2025 by Admin (Talk | contribs)
XDFly has telemetry feature built-in in the Programming port. This allows telemetry data transmission to the unit. Additionally it has support for ESC programming with Spirit Wave
1 Telemetry Cable
Warning.png We do not recommend to make this cable at home since improper connection will cause permanent damage of the unit. The Red wire must be disconnected or has to be removed always!
2 Interfacing
Connect the Telemetry cable to the primary Spektrum satellite port (SAT1) in the unit - apply for Spirit 2, Spirit RS, Spirit Pro, Spirit GT, Spirit GTR, Spirit W1.
There is no support for Spirit v1 units.
Servo connector of the Telem UNI cable should be connected to the ESC - programming port. Make sure to connect Orange wire at the RX pin of the ESC.
3 Spirit Settings
3.1 Telemetry activation
Go to the Advanced/Telemetry settings and set the XDFly & ZTW & OMP option.
4 Displaying telemetry data
