ESC telemetry
The ESC telemetry is feature that allows you to display data from your Electronic Speed Controller (ESC) directly in the transmitter. Depending on transmitter capabilities you can Log the values and use them for a various purposes.
The ESC telemetry is mediated through the Spirit units as these are able to read the data and communicate with both receiver and ESC at the same time.
1 List of supported Radios
2 List of supported ESCs
- Castle Creations Phoenix & Talon
- HobbyWing Platinum V4
- HobbyWing Platinum V5
- Scorpion Tribunus
- Kontronik KOSMIK & JIVE PRO (Deprecated)
- Kontronik JIVE
- YGE LVT/HVT/Aureus
- Kontronik TelMe Telemetry - KOSMIK, JIVE PRO, KOLIBRI
- Graupner Telemetry
- OMP & ZTW Telemetry
- Spektrum Avian Telemetry
- XDFly Telemetry
3 Interfacing
4 Telemetry data
- Battery Voltage [V]
- Battery Current [A]
- BEC Voltage [V] - provided by ESC Telemetry or Receiver.
- Consumed Capacity [mAh] - Battery Capacity consumed from the initialization point.
- ESC Temperature [°C] - Usually temperature of the FET transistors.
- Head Speed [RPM] - provided by RPM sensor or ESC. (also with ESC Telemetry disabled)
- Vibration Level [%] - provided by unit itself. (also with ESC Telemetry disabled)
- Altitude [%] - provided by Spirit GT, GTR, W1, GeoLink units. (also with ESC Telemetry disabled)
