HoTT Telemetry
Revision as of 07:32, 15 September 2025 by Admin (Talk | contribs)
čeština • ‎Deutsch • ‎English • ‎español • ‎français • ‎italiano • ‎русский
Graupner HoTT ESC has telemetry feature built-in in the Programming port. This allows telemetry data transmission to the unit. To allow the ESC telemetry, it is necessary to have updated ESC firmware to a more recent.
It is important to flash firmware with Sensor Emulation called EAM - Electric Air Module.
1 Telemetry Cable
To allow the telemetry data transmission the JST-Servo adapter is required. This cable is available in our Eshop.
Warning.png It is very important to modify the cable correctly, otherwise permanent damage of the Spirit unit will occur!
1.1 Cable modification
Extremely important is the following Modification of the JST-Servo adapter cable. It is required to unplug or cut RED wire of the adapter as displayed at the photo.
2 Interfacing
Servo connector of the Telem UNI cable should be connected to the ESC - telemetry/programming port.
350px
3 Spirit Settings
3.1 Telemetry activation
Go to the Advanced/Telemetry settings and set the Graupner HoTT option.
4 Displaying telemetry data
Warning.png Please update your ESC firmware to the most recent firmware. It is important to flash firmware with Sensor Emulation called EAM - Electric Air Module.
5 Supported models
Battery Voltage
Battery Current
Consumed Capacity
ESC Temperature
RPM
Graupner Cool Control +T 160HV
Other unlisted models that are telemetry enabled with a proper firmware should work too.
