Spirit_Wave_Model/de
Revision as of 11:16, 28 December 2025 by ErnieDembowsky (Talk | contribs) (Created page with "Ein Modell anlegen")
1 New Model
Um die Spirit Wave zu nutzen, ist es erforderlich, ein sogenanntes „Modell“ anzulegen. Jedes im Sender angelegte Modell kann mit einem bestimmten Empfänger gebunden werden.
Aus diesem Grund ist es üblich, mehrere Modelle im Wave-Sender zu speichern, jeweils eines für jedes Ihrer physischen RC-Modelle. In other words, one Model per each R/C model.
Der Spirit Wave-Sender verfügt über ein standardmäßig vorerstelltes Modell (für Hubschrauber), wenn er zum ersten Mal gestartet wird oder nach dem Zurücksetzen auf Werkseinstellungen.
1.1 Ein Modell anlegen
Press at the Home icon at the bottom panel.
Continue with the CREATE button and confirm Dialog with YES.
From then choose appropriate Model Type that correspond to your R/C model.
Info.png If it is unlisted type such as a Boat you can use other type - for example Car.
Each Model Type has different Setup Wizard that reflects physical properties of the R/C model, for this reason it is important to select it correctly.
1.1.1 Helicopter
Spirit Wave radio can be connected with any Flybarless controller.
  • If you are using Spirit FBL unit, choose Spirit unit (Heli firmware) option.
  • For models with no controller (Receiver Only) or for controllers such as MSH Brain, Mikado VBar, BeastX Microbeast, Bavarian Demon Axon or other, select Spirit Receiver Only.
Continue by using a Swipe gesture to enter Model Name.
1.1.2 Plane
Spirit Wave radio can be connected with any stabilisation controller.
  • If you are using Spirit unit, choose Spirit unit (Aero firmware) option.
  • For models with no controller (Receiver Only) or for controllers such as Bavarian Demon Cortex select Spirit Receiver Only.
1.2 Model Setup
Once model is created you can bind it with a receiver according Binding section. Then depending on Model Type you can adjust it's parameters.
