Spirit_Wave_FlightMode/de
Revision as of 11:48, 28 December 2025 by ErnieDembowsky (Talk | contribs)
1 Flugzustände
Flug-Modi werden verwendet, um unterschiedliche Verhaltensweisen des Modells zu konfigurieren.
Ein Flug-Modus kann unterschiedliche Einstellungen enthalten, wie zum Beispiel:
  • Gas-Kurve
  • Pitch-Kurve
  • Dual Rate
  • Expo-Kurve
  • Trimmungen
  • Kreisel-Empfindlichkeit
  • Parameter des Spirit-Controllers
Alle diese Einstellungen werden im Spirit Wave-Sender gespeichert und sofort angewendet, sobald der jeweilige Flug-Modus aktiv ist.
Beispiel mit 4 Flug-Modi, wobei der Flug-Modus „Normal 2“ aktiv ist.
1.1 Eigenschaften
Jeder Flug-Modus besitzt die folgenden Eigenschaften:
  • Name
  • Eingang (Schalter)
  • Aktive Poisition des Eingangs
  • Priorität
  • Verzögerung
  • Sprachausgabe
When a new Model profile is created, only one Flight Mode is available. It is possible to create unlimited amount of new Flight Modes. All Flight Mode related settings can be found at the Model - Flight Mode menu.
To easily distinguish Flight Mode you can always see it's name at the left side of the Top system panel. You can configure name of each Flight Mode as needed.
For Flight Mode to be active it is required to set Input and then set at which Input's position the Flight Mode should be active. Default Input is Switch LU at the front left, upper side of the radio. It is common to use 2 or 3-state switch for this purpose. Position for each Input can be individually configured as needed. If only one Flight Mode is created, there is no need to adjust Input nor Position
You can set same or different Input for more Flight Modes. If Input (Switch) is used for multiple Flight Modes, the radio will determine which Flight Mode is active based on Active Position only.
If there are conditions during which radio can't determine active Flight Mode, it is determined by a configured Priority. The lower priority value is, the higher is the priority. Flight Modes are sorted according their Priority in the Flight Mode list. Flight Mode with the highest priority is at the Top of the list.
In certain cases it is required to have Flight Mode activation delayed. Even if all conditions for activation are met the system can remain at a previous Flight mode until configured Delay period will pass.
Voice Output can be individually configured for each Flight Mode. See Voice Output page.
1.2 Shared Parameters
Certain Parameters of the Model can be set as Flight Mode independent or so called Global. These parameters are following:
  • Throttle Curve
  • Collective Pitch Curve
  • Dual Rate
  • Exponential Curve
  • Trims
  • Gyro Gain
Shared Parameters can be set at the second page of the Model - Flight Mode menu and is independent of active Flight Mode. It is same for each of them. Each Model profile can have different Shared Parameters.
Info.png Example: If pilot knows that Model require same Throttle Curve always but he need more Flight Modes, then it is beneficial to enable Throttle Curve Sharing option.
By default (for each new model) Dual Rate, Expo, Trims are enabled as Shared Parameters.
