Spektrum PWM connection
Revision as of 12:41, 19 January 2017 by Admin (Talk | contribs)
This table is describing connection of the Spektrum AR6210 receiver. Because labels are same between other receivers you can use it also for other AR receivers.
PWM Wiring
UNIT RECEIVER
RUD RUD
AUX GEAR
ELE/PIT/AIL ORANGE wire to AILE
RED wire to AUX 1
BROWN wire to ELEV
Info.png Servo connectors are connected always with Orange wire closer to the labels (in the receiver and unit as well).
Info.png Special cable which ends with 3 servo connectors must be connected in the way, that these wires are always closer to the port labels.
ESC should be connected to the THRO port.
