Solucion de problemas GEOLINK
Revision as of 20:59, 22 January 2019 by Gotas (Talk | contribs) (Created page with "2X PARPADEOS")
En caso de un problema, GEOLINK notificara al piloto mediante un LED de estado incorporado. cualquier falla es señalada por un LED de estado parpadeante que se repite periodicamente. Si se produjo algun problema despues de una falla, se requiere la reparacion de GEOLINK.
El parpadeo de LED puede aparacer inmediatamente despues del encendido. Por numero de parpadeos de LED en serie, puede determinar que problema esta presente.
1 Fallos
1.1 1x parpadeo
Los datos de hardware almacenados en GEOLINK se perdieron.Es necesario contactar con el apoyo del sistema SPIRIT.
1.2 2X PARPADEOS
Pressure sensor is not operating correctly. Usually this problem occur when GeoLink is operated for prolonged time under extremely high humidity conditions. Store GeoLink in low humidity environment for few hours until internal condensate will evaporate. If this will not help contact Spirit System support.
1.3 3x blink
Gyro, accelerometer sensors are not operating correctly. Contacting Spirit System support is necessary.
1.4 4x blink
Compass sensor is not operating correctly. Contacting Spirit System support is necessary.
1.5 Constant blinking
This might happen rather in-flight and could signalize unexpected failure. Most probable reason is shock by high electrostatic discharge.
2 Other notifications
2.1 Calibration process
If you can see 3 series of fast flashing (followed by fast erratic blinks) after power up of the GeoLink then the module is in so called Calibration process. This process can be invoked by pilot through Spirit Settings and must be finished according instructions. Until finished the GeoLink will be inoperable.
