Configuration
Revision as of 12:11, 17 February 2017 by FuzzyBot (Talk | contribs) (Importing a new version from external source)
1 CONNECTION TO PC
2 CONNECTION WITH THE UNIT
Info.png If the unit is not configured yet (e.g. a new unit) it is advised to not connect rudder servo yet.
4 CONFIGURATION SOFTWARE
PROBLEMS WITH WINDOWS
5 SOFTWARE USAGE
5.1 CONNECTION TAB
Swashplate
  • PWM – standard receiver.
  • Spektrum DSM2/DSMX – DSM2 or DSMX satellite.
  • Futaba S-BUS – receiver connected via SBUS.
  • SRXL/SUMD – receiver connected via SRXL, SUMD, UDI.
Flight style
Channels
  • N – Normal (Rate)
  • HL – Head Lock
SPECTRUM ANALYSER
  • X - elevator axis
  • Y - aileron axis
  • Z - rudder axis
  8. Stop the motor.
Fa.png Good Health Message:
I.png Calibration Finished:
I.png Governor was Engaged:
Zv.png Cyclic Ring Activated:
Zv.png Rudder Limit Reached:
Tr.png Receiver Signal Lost:
Tr.png Power Voltage is low:
Servos reverse
  • Head-Lock mode: 1% to 100%
How to setup the Rescue in the unit and your transmitter is described in the Stabi mode. From version 2.3.0 you can activate selected Function by two different methods:
  • Negative Gyro Gain
  • Separate Channel (NEW)
  • ESC with RPM output
  • ESC without RPM output
