配置
1 連接到電腦
Spirit Settings適用於以下操作系統:
following section.
the following URL:
2 CONNECTION WITH THE UNIT
3 SOFTWARE INSTALLATION
installation process.
directory.
with the file „settings.sh“.
4 SOFTWARE STARTUP
PROBLEMS ON WINDOWS
manager.
PROBLEMS ON MAC
5 SOFTWARE USAGE
5.1 CONNECTION TAB
Swashplate
- PWM – standard receiver.
- Spektrum DSM2/DSMX – DSM2 or DSMX satellite.
- Futaba S-BUS – receiver connected via SBUS.
Flight style
requirements of the pilot.
Channels
channel to each function.
(See chapter 5.6).
SPECTRUM ANALYSER
- X - elevator axis
- Y - aileron axis
- Z - rudder axis
- Stop the motor.
Servo reverse
tail blow outs may occur.
- Head-Lock mode: 1% to 100%
- Negative Gyro Gain
- Separate Channel (NEW)
5.8.1 EXPERT SETTINGS
5.8.2 TELEMETRY SETTINGS
- ESC with RPM output
- ESC without RPM output
- Magnetic sensor
- Governor Response: 5
- Holding Performance: 1
| Shortcut | Function |
