配置
Revision as of 17:50, 17 May 2017 by Gabrielwong1991 (Talk | contribs) (Created page with "從桌面或安裝目錄中啟動“Spirit Settings”。")
1 連接到電腦
Spirit Settings適用於以下操作系統:
沒有需要安裝。
2 與Spirit連接
3 軟件安裝
4 軟件啟動
PROBLEMS ON WINDOWS
PROBLEMS ON MAC
If the configuration software is unable to detect the USB interface, make sure that the Driver is installed. It is very important that the version is correct else it can lead to an instability.
5 SOFTWARE USAGE
5.1 CONNECTION TAB
Swashplate
  • PWM – standard receiver.
  • Spektrum DSM2/DSMX – DSM2 or DSMX satellite.
  • Futaba S-BUS – receiver connected via SBUS.
  • SRXL/SUMD – receiver connected via SRXL, SUMD, UDI.
Flight style
Channels
SPECTRUM ANALYSER
  • X - elevator axis
  • Y - aileron axis
  • Z - rudder axis
  8. Stop the motor.
Fa.png Good Health Message:
I.png Calibration Finished:
I.png Governor was Engaged:
Zv.png Cyclic Ring Activated:
Zv.png Rudder Limit Reached:
Tr.png Receiver Signal Lost:
Tr.png Power Voltage is low:
Servo reverse
  • Head-Lock mode: 1% to 100%
  • Negative Gyro Gain
  • Separate Channel (NEW)
5.8.1 EXPERT SETTINGS
5.8.2 TELEMETRY SETTINGS
  • ESC with RPM output
  • ESC without RPM output
