配置
Revision as of 18:24, 17 May 2017 by Gabrielwong1991 (Talk | contribs) (Created page with "選擇Spirit FBL在模型安裝的位置。 ''(請見第3節 - 安裝)''")
1 連接到電腦
Spirit Settings適用於以下操作系統:
沒有需要安裝。
2 與Spirit連接
3 軟件安裝
以下是支援平台的安裝說明。 配置軟件可在Spirit System網站上找到:[1]
4 軟件啟動
從桌面或安裝目錄中啟動“Spirit Settings”。
WINDOWS上的問題
MAC的問題
5 軟件使用
確保在Spirit FBL初始化後啟動軟件。
5.1 連接選項 (CONNECTION TAB)
5.2 一般選項 (GENERAL)
位置 (Position)
Swashplate
  • PWM – standard receiver.
  • Spektrum DSM2/DSMX – DSM2 or DSMX satellite.
  • Futaba S-BUS – receiver connected via SBUS.
  • SRXL/SUMD – receiver connected via SRXL, SUMD, UDI.
Flight style
Channels
SPECTRUM ANALYSER
  • X - elevator axis
  • Y - aileron axis
  • Z - rudder axis
  8. Stop the motor.
Fa.png Good Health Message:
I.png Calibration Finished:
I.png Governor was Engaged:
Zv.png Cyclic Ring Activated:
Zv.png Rudder Limit Reached:
Tr.png Receiver Signal Lost:
Tr.png Power Voltage is low:
Servo reverse
  • Head-Lock mode: 1% to 100%
  • Negative Gyro Gain
  • Separate Channel (NEW)
5.8.1 EXPERT SETTINGS
5.8.2 TELEMETRY SETTINGS
  • ESC with RPM output
  • ESC without RPM output
