Configuration
Revision as of 14:34, 8 September 2017 by FuzzyBot (Talk | contribs) (Importing a new version from external source)
1 CONNECTION TO PC
2 CONNECTION WITH THE UNIT
3 SOFTWARE INSTALLATION
4 SOFTWARE STARTUP
PROBLEMS ON WINDOWS
PROBLEMS ON MAC
If the configuration software is unable to detect the USB interface, make sure that the Driver is installed. It is very important that the version is correct else it can lead to an instability.
5 SOFTWARE USAGE
5.1 CONNECTION TAB
Swashplate
  • PWM – standard receiver.
  • Spektrum DSM2/DSMX – DSM2 or DSMX satellite. (for Spektrum integration).
  • Futaba S-BUS – receiver connected via SBUS.
Flight style
Channels
SPECTRUM ANALYSER
  • X - elevator axis
  • Y - aileron axis
  • Z - rudder axis
  8. Stop the motor.
Fa.png Good Health Message:
I.png Calibration Finished:
I.png Governor was Engaged:
Zv.png Cyclic Ring Activated:
Zv.png Rudder Limit Reached:
Tr.png Receiver Signal Lost:
Tr.png Power Voltage is low:
Servo reverse
  • Head-Lock mode: 1% to 100%
  • Negative Gyro Gain
  • Separate Channel (NEW)
5.8.1 EXPERT SETTINGS
5.8.2 TELEMETRY SETTINGS
  • ESC with RPM output
  • ESC without RPM output
