Configuration
1 CONNECTION TO PC
following section.
the following URL:
2 CONNECTION WITH THE UNIT
3 SOFTWARE INSTALLATION
installation process.
directory.
with the file „settings.sh“.
4 SOFTWARE STARTUP
PROBLEMS ON WINDOWS
manager.
PROBLEMS ON MAC
5 SOFTWARE USAGE
5.1 CONNECTION TAB
Swashplate
- PWM – standard receiver.
- Spektrum DSM2/DSMX – DSM2 or DSMX satellite. (for Spektrum integration).
Flight style
Channels
channel to each function.
(See chapter 5.6).
SPECTRUM ANALYSER
- X - elevator axis
- Y - aileron axis
- Z - rudder axis
- Stop the motor.
Servo reverse
tail blow outs may occur.
Micro helicopters and µSpirit: When Tail rotor is driven by a dedicated motor, the Rudder ESC must be connected to the CH4 port. Rudder end-points are then used to set available Throttle range for the Rudder ESC from 0 to 100%. Left limit = 0%, Right limit = 100%. We recommend Left limit to set at 150 and Right limit to 126 for the beginning.
- Head-Lock mode: 1% to 100%
- Negative Gyro Gain
- Separate Channel (NEW)
5.8.1 EXPERT SETTINGS
Rudder - Control Type
With µSpirit units it is possible to enable support for the tail rotor driven by dedicated motor. In this case two ESC is used, where Rudder ESC is connected to the CH4 port. Important thing is to set Limits/Rudder End-Points appropriately since these are defining available Throttle range for the ESC from 0 to 100%.
5.8.2 TELEMETRY SETTINGS
- ESC with RPM output
- ESC without RPM output
- Magnetic sensor
- Governor Response: 5
- Holding Performance: 1
| Shortcut | Function |
