Configuration
Revision as of 08:56, 7 December 2017 by FuzzyBot (Talk | contribs) (Importing a new version from external source)
1 CONNECTION TO PC
2 CONNECTION WITH THE UNIT
3 SOFTWARE INSTALLATION
4 SOFTWARE STARTUP
PROBLEMS ON WINDOWS
PROBLEMS ON MAC
If the configuration software is unable to detect the USB interface, make sure that the Driver is installed. It is very important that the version is correct else it can lead to an instability.
5 SOFTWARE USAGE
5.1 CONNECTION TAB
Swashplate
Flight style
Channels
SPECTRUM ANALYSER
  • X - elevator axis
  • Y - aileron axis
  • Z - rudder axis
  8. Stop the motor.
Fa.png Good Health Message:
I.png Calibration Finished:
I.png Governor was Engaged:
Zv.png Cyclic Ring Activated:
Zv.png Rudder Limit Reached:
Tr.png Receiver Signal Lost:
Tr.png Power Voltage is low:
Servo reverse
Info.png Micro helicopters and µSpirit: When Tail rotor is driven by a dedicated motor, the Rudder ESC must be connected to the CH4 port. Rudder end-points are then used to set available Throttle range for the Rudder ESC from 0% (Right) to 100% (Left). We recommend to set Right limit to 126 and Left limit to 150 for the beginning.
  • Head-Lock mode: 1% to 100%
  • Negative Gyro Gain
  • Separate Channel (NEW)
5.8.1 EXPERT SETTINGS
Rudder - Control Type
With µSpirit units it is possible to enable support for the tail rotor driven by dedicated motor. In this case two ESC is used, where Rudder ESC is connected to the CH4 port. Important thing is to set Limits/Rudder End-Points appropriately since these are defining available Throttle range for the ESC from 0 to 100%. Normally this parameter is available in the Setup Wizard.
5.8.2 TELEMETRY SETTINGS
  • ESC with RPM output
  • ESC without RPM output
7.5 Transmitter
7.6 Fine-Tuning Procedure
