Configuration
Revision as of 17:23, 3 August 2018 by Admin (Talk | contribs)
1 CONNECTION TO PC
For proper functionality it is important to download and install the driver from the following URL: OSX - 10.12 OSX - 10.13+
2 CONNECTION WITH THE UNIT
3 SOFTWARE INSTALLATION
Extract all the files from the downloaded archive to, for example, your home directory. Configuration software can be launched from the newly created directory with the file „settings.sh“. Linux Mint (or compatible) installation guide is available at Spirit Settings under Linux page.
4 SOFTWARE STARTUP
PROBLEMS ON WINDOWS
PROBLEMS ON MAC
If the configuration software is unable to detect the USB interface, make sure that the Driver is installed. It is very important that the version is correct else it can lead to an instability.
5 SOFTWARE USAGE
5.1 CONNECTION TAB
Swashplate
Flight style
Channels
SPECTRUM ANALYSER
  • X - elevator axis
  • Y - aileron axis
  • Z - rudder axis
  8. Stop the motor.
Fa.png Good Health Message:
I.png Calibration Finished:
I.png Governor was Engaged:
Zv.png Cyclic Ring Activated:
Zv.png Rudder Limit Reached:
Tr.png Receiver Signal Lost:
Tr.png Power Voltage is low:
Info.png Micro helicopters and µSpirit: When Tail rotor is driven by a dedicated motor, the Rudder ESC performance can be noticeably improved by configuring Low RPM value to achieve the lowest spinning RPM for the Tail rotor. This can be configured by Subtrim (CH4) - Low RPM - this parameter has impact on lift off and symmetrical turning performace.
Servo reverse
  • Head-Lock mode: 1% to 100%
  • Negative Gyro Gain
  • Separate Channel (NEW)
5.8.1 EXPERT SETTINGS
Rudder - Control Type
5.8.2 TELEMETRY SETTINGS
  • ESC with RPM output
  • ESC without RPM output
Fine-Tuning - Holding Limit
7.5 Transmitter
7.6 Fine-Tuning Procedure
