Конфигурация.
1 ПОДКЛЮЧЕНИЕ К ПК
OSX - 10.12
OSX - 10.13+
Ничего устанавливать не нужно
2 СОЕДИНЕНИЕ С УСТРОЙСТВОМ
installation process.
directory.
with the file „settings.sh“.
4 SOFTWARE STARTUP
PROBLEMS ON WINDOWS
manager.
PROBLEMS ON MAC
5 SOFTWARE USAGE
5.1 CONNECTION TAB
Swashplate
- PWM – standard receiver.
- Spektrum DSM2/DSMX – DSM2 or DSMX satellite. (for Spektrum integration).
Flight style
Channels
channel to each function.
(See chapter 5.6).
SPECTRUM ANALYSER
- X - elevator axis
- Y - aileron axis
- Z - rudder axis
- Stop the motor.
Servo reverse
tail blow outs may occur.
- Head-Lock mode: 1% to 100%
- Negative Gyro Gain
- Separate Channel (NEW)
5.8.1 EXPERT SETTINGS
Rudder - Control Type
5.8.2 TELEMETRY SETTINGS
- ESC with RPM output
- ESC without RPM output
- Magnetic sensor
Fine-Tuning - Holding Limit
7.5 Transmitter
7.6 Fine-Tuning Procedure
- Governor Response: 5
- Holding Performance: 1
Shortcut | Function |
ESC | Exit current window. |
