Konfiguráció
A beállítást a szoftver segítségével végezzük el, amely ötvözi a hatékonyságot és az egyszerűséget, miközben állítható paramétereket kínál, beleértve a speciális paramétereket.
A szoftver felkínálja a Telepítő varázslót. Nagyon ajánlott a varázsló használata, mivel ez végig vezeti a teljes konfiguráción az elejétől az első repülésig.
1 CSATLAKOZÁS A SZÁMÍTÓGÉPHEZ
following section.
the following URL:
OSX - 10.12
OSX - 10.13+
2 CONNECTION WITH THE UNIT
3 SOFTWARE INSTALLATION
installation process.
directory.
with the file „settings.sh“.
4 SOFTWARE STARTUP
PROBLEMS ON WINDOWS
manager.
To see how to install the software properly please visit Spirit Settings under Windows page.
PROBLEMS ON MAC
PROBLEMS ON LINUX
To see how to install the software properly please visit Spirit Settings under Linux page.
5 SOFTWARE USAGE
5.1 CONNECTION TAB
Swashplate
- PWM – standard receiver.
Flight style
Channels
channel to each function.
(See chapter 5.6).
SPECTRUM ANALYSER
- X - elevator axis
- Y - aileron axis
- Z - rudder axis
- Stop the motor.
Servo reverse
tail blow outs may occur.
- Head-Lock mode: 1% to 100%
- Negative Gyro Gain
- Separate Channel (NEW)
Rescue Duration
Once specified duration period will pass the Rescue mode will end and model will start to hover. For this purpose Hovering Collective Pitch value is used. The period is counted from time the Rescue mode was engaged. The parameter is available for both Rescue (Normal) and Rescue (Acro). Transition from Rescue to Hovering is smooth. Collective Pitch control is returned to the pilot as soon as a pitch stick movement is recognized.
5.8.1 EXPERT SETTINGS
Rudder - Control Type
5.8.2 TELEMETRY SETTINGS
First select the data file containing the firmware (*.4df) – Select button. Once the file is selected, press the Flash button. The upgrade progress will be displayed here. After completion, a confirmation dialog box should indicate a successful update.
- ESC with RPM output
- ESC without RPM output
- Magnetic sensor
Fine-Tuning - Holding Limit
7.5 Transmitter
7.6 Fine-Tuning Procedure
- Governor Response: 5
- Holding Performance: 1
| Shortcut | Function |
