Configuration
A beállítást a szoftver segítségével végezzük el, amely ötvözi a hatékonyságot és az egyszerűséget, miközben állítható paramétereket kínál, beleértve a speciális paramétereket.
The software offers the Setup Wizard. It is highly recommended to use the
wizard as it will guide you through entire configuration from the beginning to
the first flight.
1 CONNECTION TO PC
following section.
the following URL:
OSX - 10.12
OSX - 10.13+
2 CONNECTION WITH THE UNIT
3 SOFTWARE INSTALLATION
installation process.
directory.
with the file „settings.sh“.
4 SOFTWARE STARTUP
PROBLEMS ON WINDOWS
manager.
To see how to install the software properly please visit Spirit Settings under Windows page.
PROBLEMS ON MAC
PROBLEMS ON LINUX
To see how to install the software properly please visit Spirit Settings under Linux page.
5 SOFTWARE USAGE
5.1 CONNECTION TAB
Swashplate
- PWM – standard receiver.
Flight style
Channels
channel to each function.
(See chapter 5.6).
SPECTRUM ANALYSER
- X - elevator axis
- Y - aileron axis
- Z - rudder axis
- Stop the motor.
Servo reverse
tail blow outs may occur.
- Head-Lock mode: 1% to 100%
- Negative Gyro Gain
- Dedicated Channel
Rescue Duration
5.8.1 EXPERT SETTINGS
Rudder - Control Type
Stabi Correction
5.8.2 TELEMETRY SETTINGS
First select the data file containing the firmware (*.4df) – Select button. Once the file is selected, press the Flash button. The upgrade progress will be displayed here. After completion, a confirmation dialog box should indicate a successful update.
- ESC with RPM output
- ESC without RPM output
- Magnetic sensor
Fine-Tuning - Holding Limit
7.5 Transmitter
7.6 Fine-Tuning Procedure
- Governor Response: 5
- Holding Performance: 1
| Shortcut | Function |
