Configurazione
Revision as of 17:10, 12 January 2021 by DaniloB (Talk | contribs) (Created page with "COLLEGAMENTO CON L'UNITÀ")
1 CONNESSIONE AL PC
Installa il driver tramite il programma di installazione del software. Questo processo sarà descritto in a sezione seguente.
Per una corretta funzionalità è importante scaricare e installare il driver da il seguente URL: OSX - 10.12 OSX - 10.13+
Il software Spirit Settings può essere connesso al modulo Wifi da ora. Si chiama "Spirit Wifi-Link" ". Wifi-Link può sostituire completamente l'interfaccia USB. Così l'utente può eseguire tutte le impostazioni in modalità wireless. È possibile trovare la descrizione della connessione nella pagina delle istruzioni Wifi-Link.
2 COLLEGAMENTO CON L'UNITÀ
3 SOFTWARE INSTALLATION
Extract all the files from the downloaded archive to, for example, your home directory. Configuration software can be launched from the newly created directory with the file „settings.sh“. Linux Mint (or compatible) installation guide is available at Spirit Settings under Linux page.
4 SOFTWARE STARTUP
PROBLEMS ON WINDOWS
If the configuration software is unable to detect a valid COM port, you can try starting the software as Administrator. Alternatively, check the COM port number. If the value is too high try reconfiguring the port number (Silabs device) to, for example, COM1 – COM4. For notebooks it is also worth disabling any USB power saving features in Device manager. To see how to install the software properly please visit Spirit Settings under Windows page.
PROBLEMS ON MAC
If the configuration software is unable to detect the USB interface, make sure that the Driver is installed. It is very important that the version is correct else it can lead to an instability.
PROBLEMS ON LINUX
To see how to install the software properly please visit Spirit Settings under Linux page.
5 SOFTWARE USAGE
5.1 CONNECTION TAB
Swashplate
  • PWM – standard receiver.
Flight style
Channels
SPECTRUM ANALYSER
  • X - elevator axis
  • Y - aileron axis
  • Z - rudder axis
  8. Stop the motor.
Fa.png Good Health Message:
I.png Calibration Finished:
I.png Governor was Engaged:
Zv.png Cyclic Ring Activated:
Zv.png Rudder Limit Reached:
Tr.png Receiver Signal Lost:
Tr.png Power Voltage is low:
Servo reverse
  • Head-Lock mode: 1% to 100%
  • Negative Gyro Gain
  • Dedicated Channel
Rescue Duration
5.8.1 EXPERT SETTINGS
Rudder - Control Type
Stabi Correction
5.8.2 TELEMETRY SETTINGS
