Spektrum Integrazione
Revision as of 22:12, 19 February 2022 by DaniloB (Talk | contribs) (Created page with "Cablaggio del ricevitore")
Spektrum integration is available for all the latest telemetry enabled Spektrum receivers!
Ciò significa che puoi configurare completamente le unità Spirit con i trasmettitori Spektrum in tempo reale senza bisogno di un computer.
1 Requisiti
  • Trasmettitore Spektrum: DX6e, DX6 Gen 2, DX6 Gen 3, DX7 Gen 2, DX8 Gen 2, DX9, DX10T, DX18 Gen 1, DX18 Gen 2, DX18T, DX18QQ, DX20, IX12, IX20, NX6, NX8, NX10
  • Serial Telemetry receiver: SPM4649T, SPM4650, SPM4651, SPM9747, AR6610T.
  • Cable - depending on your receiver (see Wiring section).
2 Cablaggio del ricevitore
Currently there are two different options.
  • SPM4649T receiver - solution compatible with older Spektrum satellites
  • SRXL2 receivers - recommended for new builds
Please note you can use SRXL2 receiver only together with other SRXL2 satellites.
2.1 SPM4649T Receiver Wiring
2.2 SRXL2 Receiver Wiring
3.1 Aggiornamento del firmware
Update your transmitter to the latest firmware from the Spektrum Airware portal. In the menu SETUPS/UPDATES - FIRMWARE UPDATES you will find the firmware for download. The SAX file must be stored on the SDCARD and inserted in your transmitter. In the System Setup/Transfer SD Card you can select Firmware update as Option.
  • DX6e non necessita di aggiornamento (la versione 1.00 funzionerà).
With the latest Spektrum NX radiso, please make sure to install the latest firmware 3.06, otherwise integration will not work.
3.2 Configurazione
Accendere il trasmettitore e nel Menu principale entrare in Telemetria.
Configure:
  • 1: ESC
  • 2: Text Gen (only for older radio firmware)
  • 3: Flight Pack mAh
When adding Text Gen make sure that Display option is configured to Act or Roller (depending on radio). Please note, recent radio update do not require any Text Gen settings. After activating the integration menu, you can view the Text Gen screen by using roller at the Telemetry monitor page.
A questo punto il tuo trasmettitore è pronto. Puoi tornare alla schermata principale.
4 Menu di integrazione
Ogni volta che l'unità viene inizializzata, è possibile accedere al menu Spektrum Integration o guardare i dati di telemetria.
Avvia il trasmettitore e sulla schermata principale usa un rullo: ruota verso destra finché non vedrai uno Schermata vuota.
4.1 Entrare nel menu
A questo punto il menu di integrazione è chiuso e non è possibile configurare accidentalmente alcun parametro. Per aprire il menu, spostare lo stick del timone a destra e lo stick degli alettoni a sinistra e tenerlo premuto per oltre 2 secondi. Una volta aperto il menu, vedrai il messaggio <PRONTO>. Ora puoi rilasciare le levette e sei pronto per impostare tutti i parametri.
4.2 Chiusura del menu
Non appena vorrai chiudere il menù Integrazione (quando vorrai volare) esegui la stessa procedura con le bacchette. Muovi e tieni premuti gli stick (timone a destra e alettone a sinistra) per oltre 2 secondi. Il menu viene chiuso correttamente quando viene visualizzato <CLOSED> anche se riporterai le levette al centro. Se non chiuderai il menu di integrazione, verrà temporaneamente disabilitato non appena la curva del gas supererà il 15%. Ma per ridurre al minimo qualsiasi rischio, consigliamo vivamente di chiuderlo correttamente.
4.3 Navigazione
Il layout del menu è quasi identico al software del PC per una facile navigazione.
Funziona allo stesso modo di quando è collegato il software per PC. Ciò significa che quando si apre il menu di integrazione di Spektrum, è possibile modificare anche i parametri di base che potrebbero influire in modo significativo sull'elicottero.
Info.png Per navigare nel menu puoi usare le levette degli alettoni e dell'elevatore.
  • Alettone a sinistra - Indietro nel menu; Interrompi la modifica del valore di un parametro.
  • Alettone a destra - Entra in un sottomenu; Modifica il parametro selezionato.
  • Elevatore su - Vai su nel menu o sottomenu; Aumenta il valore del parametro selezionato.
  • Elevator Down - Scendi nel menu o sottomenu; Diminuisce il valore del parametro selezionato.
Warning.png Non eseguire mai la configurazione durante il volo!
Quando si utilizzano le funzioni di cambio banco o di sintonizzazione in tempo reale mentre l'integrazione è attiva, il menu ne avrà il pieno controllo. L'unità non reagirà a un cambio di posizione dell'interruttore. Per il cambio di banco c'è un parametro Banco nel menu principale dove puoi cambiare manualmente i banchi.
Non dimenticare di utilizzare Salva impostazioni quando desideri salvare le modifiche in modo permanente.
5 Dati di telemetria
Ora è il momento giusto per configurare telemetria ESC "(se si desidera utilizzare questa funzione)".
Se la funzione non viene utilizzata, verranno comunque visualizzate le variabili di telemetria come il livello di vibrazione, la percentuale di accelerazione ed eventualmente la lettura dell'RPM come descritto di seguito. Questi verranno visualizzati automaticamente se la fase di preparazione del trasmettitore è terminata.
5.1 Visualizzazione dei dati
Per visualizzare i dati di telemetria, muovi il selettore mentre sei sulla schermata principale finché non vedrai Stato ESC.
Se non riesci a vedere lo Stato ESC, assicurati di aver eseguito la configuration.
Elenco delle variabili di telemetria disponibili:
  • RPM [Head RPM] - RPM fornito da RPM sensor o ESC.
  • Volts [V] - ESC Telemetry | Tensione della batteria principale
  • Motor [A] - ESC Telemetry | Tensione della batteria principale
  • Throttle [%] - Percentuale di accelerazione inviata all'ESC
  • FET Temp [°C] - ESC Telemetry | FET temperatura
  • Capacity [mAh] - ESC Telemetry | Capacità consumata dalla batteria principale
  • BEC [V] - ESC Telemetry | Tensione BEC
6 Risoluzione dei problemi
6.1 SPM4649T sempre in modalità binding
Questo problema può essere risolto in modo da eseguire nuovamente il flashing del Bootloader dell'unità alla versione più recente. Tutte le unità fornite con firmware precedente alla 2.4.3 ne avranno bisogno.
Può essere fatto facilmente in modo da eseguire nuovamente il processo di flashing (con l'ultimo file 4df), ma prima di fare clic sul pulsante Flash, premere i tasti CTRL + B. Una volta premuto, vedrai il messaggio " Stato: sovrascrittura del bootloader ". Quindi fare clic sul pulsante Flash. Il lampeggiamento richiederà un po 'più di tempo del solito (fatto in due fasi).
Warning.png Aggiorna il bootloader solo se sei certo che il normale flashing del firmware funzioni correttamente sul tuo computer.
