Configuration
1 CONNECTION A UN PC
Pour un bon fonctionnement il est important de télécharger et installer le pilote de périphérique venant de l'adresse URL suivante:
2 CONNEXION AU MODULE
installation process.
directory.
with the file „settings.sh“.
4 CONFIGURATION SOFTWARE
PROBLEMS WITH WINDOWS
manager.
5 SOFTWARE USAGE
5.1 CONNECTION TAB
Swashplate
PWM – standard receiver.
PPM – single line connection.
Flight style
requirements of the pilot.
Channels
channel to each function.
(See chapter 5.6).
as well.
- N – Normal (Rate)
- HL – Head Lock
SPECTRUM ANALYSER
- X - elevator axis
- Y - aileron axis
- Z - rudder axis
- Stop the motor.
Cyclic servos reverse
tail blow outs may occur.
- Head-Lock mode: 1% to 100%
- ESC with RPM output
- ESC without RPM output
- Magnetic sensor
- Governor Response: 5
- Holding Performance: 1
| Shortcut | Function |
