HobbyWingV5 Telemetry
Revision as of 07:06, 15 September 2025 by Admin (Talk | contribs) (Marked this version for translation)
čeština • ‎Deutsch • ‎English • ‎español • ‎français • ‎italiano • ‎русский
HobbyWing Platinum V5 ESC has telemetry feature built-in in the Programming port. This allows telemetry data transmission to the unit.
1 Telemetry Cable
2 Interfacing
Connect the Telemetry cable to the primary Spektrum satellite port (SAT1) in the unit - apply for Spirit 2, Spirit RS, Spirit Pro, Spirit GT, Spirit GTR, Spirit W1.
There is no support for Spirit v1 units.
3 Spirit Settings
3.1 Telemetry activation
Go to the Advanced/Telemetry settings and set the HobbyWing Platinum V5 option.
If using Spirit Wave you can do the same settings at Model - ESC - Type page.
4 Displaying telemetry data
5 Supported models
Battery Voltage
Battery Current
Consumed Capacity
ESC Temperature
RPM
Platinum 80A V5 ✔ ✔ ✔ ✔ ✔
Platinum 150A V5 ✔ ✔ ✔ ✔ ✔
Platinum 180A HV V5 ✔ ✔ ✔ ✔ ✔
Platinum 260A HV V5 ✔ ✔ ✔ ✔ ✔
