YGE Telemetry
Revision as of 07:21, 15 September 2025 by Admin (Talk | contribs)
YGE LVT and YGE HVT ESCs have telemetry feature built-in in the Programming port. This allows telemetry data transmission to the unit. To allow the ESC telemetry, it is necessary to have updated ESC as the older firmware versions were not supporting it.
1 Telemetry Cable
To allow the telemetry data transmission the JST-Servo adapter is required. This cable is available in our Eshop.
Warning.png It is very important to modify the cable correctly, otherwise permanent damage of the Spirit unit will occur!
1.1 Cable modification
Extremely important is the following Modification of the JST-Servo adapter cable. It is required to unplug or cut RED wire of the adapter as displayed at the photo.
2 Interfacing
Connect modified JST-Servo adapter to the primary Spektrum satellite port (SAT1) in the unit. Smaller Spirit units will utilize the one native Spektrum satellite port (μSpirit - SAT port).
Servo connector of the JST-Servo adapter cable should be connected with the Blue Servo connector of the YGE ESC.
3 Spirit Settings
3.1 Telemetry activation
Go to the Advanced/Telemetry settings and set the YGE LVT/HVT option.
If using Spirit Wave you can do the same settings at Model - ESC - Type page.
4 Displaying telemetry data
5 Supported models
Battery Voltage
BEC Voltage
Battery Current
Consumed Capacity
ESC Temperature
RPM
YGE LVT
YGE HVT
YGE Aureus
YGE Saphir
