TelMe Telemetry
Revision as of 08:31, 15 September 2025 by Admin (Talk | contribs) (Marked this version for translation)
Kontronik ESCs are utilizing special 5-pin port connector for telemetry data transmission to the unit. To allow the ESC telemetry, it is necessary to have updated ESC to at least 1.13 (JIVE PRO) and 4.14 (KOSMIK) firmware version. Older versions do not support TelMe protocol.
1 Telemetry Cable
To allow the telemetry data transmission the Telem KONTRONIK v2 cable is required. This cable is available in our Eshop.
Warning.png We do not recommend to make this cable at home since improper connection will cause permanent damage of the unit.
2 Interfacing
Connect the Telemetry cable to the primary Spektrum satellite (SAT1) port in the unit. Smaller Spirit units will utilize the one native Spektrum satellite port (μSpirit - SAT port).
5-pin JST connector of the Telem KONTRONIK v2 cable should be connected to the ESC. In case of Kontronik KOSMIK please use port in the middle.
3 Spirit Settings
3.1 Telemetry activation
Go to the Advanced/Telemetry settings and set the Kontronik TelMe option.
4 Displaying telemetry data
5 Supported models
Battery Voltage
Battery Current
BEC Voltage
Consumed Capacity
ESC Temperature
RPM
KOLIBRI 140 LV
JIVE PRO 80+ HV
JIVE PRO 120+ HV
KOSMIK 160 HV
COOL KOSMIK 160 HV
KOSMIK 200 HV
COOL KOSMIK 200+ HV
COOL KOSMIK 200 HV GOLD
