Configuration
Revision as of 12:01, 27 September 2016 by Jocelynr (Talk | contribs) (Created page with "Cette fonctionnalité permet d'utiliser simultanément 3 paramétres ou fonctions différents.")
1 CONNECTION A UN PC
2 CONNEXION AU MODULE
4 LOGICIEL DE CONFIGURATION
PROBLEMES AVEC WINDOWS
5 UTILISATION DU LOGICIEL
5.1 ONGLET CONNEXION
Swashplate (Plateau cyclique)
Récepteur
PWM – Récepteur standard.
PPM – Connexion à un fil.
Flight Style (Style de vol)
Channels (Voies)
Réglage en temps réel
  • N – Normal (Rate)
  • HL – Head Lock
SPECTRUM ANALYSER
  • X - elevator axis
  • Y - aileron axis
  • Z - rudder axis
  8. Stop the motor.
Fa.png Good Health Message:
I.png Calibration Finished:
I.png Governor was Engaged:
Zv.png Cyclic Ring Activated:
Zv.png Rudder Limit Reached:
Tr.png Receiver Signal Lost:
Tr.png Power Voltage is low:
Cyclic servos reverse
  • Head-Lock mode: 1% to 100%
WARNING
  • ESC with RPM output
  • ESC without RPM output
