Configuration
Revision as of 10:53, 12 January 2017 by Admin (Talk | contribs) (Created page with "Stabilization (Scale)/cs")
1 CONNECTION TO PC
2 CONNECTION WITH THE UNIT
4 CONFIGURATION SOFTWARE
PROBLEMS WITH WINDOWS
5 SOFTWARE USAGE
5.1 CONNECTION TAB
Swashplate
  • PWM – standard receiver.
  • Spektrum DSM2/DSMX – DSM2 or DSMX satellite.
  • Futaba S-BUS – receiver connected via SBUS.
  • SRXL/SUMD – receiver connected via SRXL, SUMD, UDI.
Flight style
Channels
Info.png It is recommended to always carry extreme caution to not lose control of the model!
  • N – Normal (Rate)
  • HL – Head Lock
SPECTRUM ANALYSER
  • X - elevator axis
  • Y - aileron axis
  • Z - rudder axis
  8. Stop the motor.
Fa.png Good Health Message:
I.png Calibration Finished:
I.png Governor was Engaged:
Zv.png Cyclic Ring Activated:
Zv.png Rudder Limit Reached:
Tr.png Receiver Signal Lost:
Tr.png Power Voltage is low:
Cyclic servos reverse
  • Head-Lock mode: 1% to 100%
  • Záchrana (Normál) - Recovers the model to an upright horizontal position – skids always to the ground. This recovery mode is great for the beginners.
  • Záchrana (Akro) - Recovers the model to a horizontal position, inverted or upright, whichever is closer at the time of activation. For intermediatte and advanced pilots that are flying acrobatic manouvers.
  • Stabilizace (Normál) - stabilization mode - skids always to the ground. This mode is good for learning the basics such as hovering and slow transitions. Model is always pushed to the horizontal position.
  • Stabilizace (Akro) - Stabilization (Acro) – stabilization mode - inverted or upright, whichever is closer at the time of activation. This mode is used for learning the basics of acrobatic maneuvers. If the sticks are in the center, the model has tendency for returning to the horizontal position.
  • Coaxial - Coaxial – stabilization mode - inverted or upright, whichever is closer at the time of activation. The steering behavior is very similar to a coaxial helicopters. Great for learning a hovering practices.
  • ESC with RPM output
  • ESC without RPM output
  • List of the supported RPM sensors and their wiring will be updated on the
