Problemas y soluciones
Revision as of 11:01, 19 September 2016 by Spiritdm (Talk | contribs) (Created page with "Movimiento de paso cíclico agresivo o huida de avance rápido conduce a rápidos, grandes oscilaciones de la cola")
Descipcion de problema Solucion
Derivas en Plato cíclico o cola después de la inicialización Compruebe trim ysubtrims. Sticks en posición de punto muerto debe ser 0%, consulte la ficha Diagnóstico. Aumentar banda muerta del palillo en la pestaña Avanzado.
Cola y ciclico no es preciso. Aumentar la ganancia cíclica y/o aumentar la ganancia del giróscopo en el transmisor. Añadir exponencial en el transmisor.
Movimiento de paso cíclico agresivo o huida de avance rápido conduce a rápidos, grandes oscilaciones de la cola Decrease pirouette consistency in the Advanced tab gradually by 10 until this disappears. Check the tail mechanics for binding.
Model oscillates in elevator or aileron axes Decrease cyclic gain in Sensor tab.
Tail oscillates rapidly Decrease gyro gain in the transmitter.
Model pirouette rotation is too slow/fast Increase/decrease rotation speed for rudder in Sensor tab.
Servos jitter randomly without external influences Check the cable connection between the receiver and the unit.
During stationary pirouettes model drifts Check the Subtrim configuration in the Servos tab. It seems to be inprecise.
Aggressive elevator stick movement leads to bouncing Increase elevator filter in Advanced tab and/or decrease cyclic feed forward in Advanced tab.
Cyclic feel is delayed or disconnected Increase cyclic feed forward in Advanced tab.
Elevator servo is not moving when initialization is finished Flight log from the previous flight was saved. View the log in the Diagnostic tab and fix reported problem.
Swashplate is jumping in a cycle when initialization is finished The unit was started with the Rescue mode engaged. Turn off the rescue from your transmitter.
Rudder stop is not equal for both sides Check rudder servo center position, rudder mechanics. You can also try to lower rudder limit for the side where bounce-back occur.
