Wifi-Link
Revision as of 21:26, 1 November 2017 by GoblinShefford (Talk | contribs) (Created page with "Jusqu'à 50 mètres")
Wifi-Link
manuel
1 Spécifications
Alimentation: 3.3V - 15V
Poids 7g
Dimension 21x32x5.5mm
Distance d'opération: Jusqu'à 50 mètres
Modes: AP, AP+Client, Client
Standard: 802.11b/g/n
Chiffrement Open, WEP, WPA, WPA2
Configuration Web Interface
Consommation d'énergie 80 – 350mA
Supported devices:
  • Android (disponible sur Google Play)
  • Tous les cellullaires, tablette et smart Tv avec navigateur web
  • PC
  • Mac
Support pour les mises a jour logiciel
Web based Spirit Settings app in the module!
2 CONNECTION
Example: Photo Cablage
Wire Meaning
GND Ground powering lead
Info.png TX wire must be always closer to the SYS label. RX wire must be always in the center pin of the SYS port.
Warning.png Do not connect communication cable to the power supply! It can be connected only to the SYS port.
3 CONFIGURATION
    The module is by default in the Access Point mode.
    You can connect to the AP directly in a normal way.
    After connection, your device will get IP address automaticaly.
  2. Open your web browser.
    Usually any modern web browser with JavaScript support can be used.
    By entering „192.168.4.1“ you will get into the configuration.Here you can change any parameter including changing SSID,password or wireless mode.
Info.png For beginners, we recommend default settings.
Module is able to connect to an existing WiFi station (e.g. your home network). By entering the configuration interface, you can set the AP+Client mode. In this mode you can find your network and connect to it. In this way, module can be accessed from any device, that is connected to the same network, even via an ethernet cable.
If you are connected to an existing WiFi station, the module will receive second IP address. You can find such IP address in the configuration interface.
You can connect to the interface from the second IP address when accessing from your network. You can also access the internet or module at the same time.
4 USAGE
Native Android app
Native PC & Mac app
