Wifi-Link
1 Spécifications
- Alimentation: 3.3V - 15V
- Poids 7g
- Dimension 21x32x5.5mm
- Distance d'opération: Jusqu'à 50 mètres
- Modes: AP, AP+Client, Client
- Standard: 802.11b/g/n
- Chiffrement Open, WEP, WPA, WPA2
- Configuration Web Interface
- Consommation d'énergie 80 – 350mA
Appareils supportés:
- Android (disponible sur Google Play)
- Tous les cellullaires, tablette et smart Tv avec navigateur web
- PC
- Mac
- Support pour les mises a jour logiciel
- Configuration accessible via un navigateur web inclus dans le module!
2 CONNECTION
| Schéma du câblage | |
| VCC | Positive powering lead: 3.3V – 15V |
| GND | Ground powering lead |
| RX | Communication lead; SYS port |
| TX | Communication lead; SYS port |
3 CONFIGURATION
Spirit Wifi-Link vous offre une utilisation facile via n'importe quelle appareil supportant le WIFI et possédant un navigateur web
Pour afficher l'utilitaire de configuration vous pouvez utiliser cette méthode:
- Connect to the Wifi module.
- Default SSID (Wifi site name): Spirit Wifi-Link.
- The module is by default in the Access Point mode.
- You can connect to the AP directly in a normal way.
- After connection, your device will get IP address automaticaly.
- Open your web browser.
- Usually any modern web browser with JavaScript support can be used.
- By entering „192.168.4.1“ you will get into the configuration.Here you can change any parameter including changing SSID,password or wireless mode.
- Module is able to connect to an existing WiFi station (e.g. your home network). By entering the configuration interface, you can set the AP+Client mode. In this mode you can find your network and connect to it. In this way, module can be accessed from any device, that is connected to the same network, even via an ethernet cable.
4 USAGE
- Go to the Settings/Wi-Fi in the system, search for a new networks.
Native Android app
- Download the latest „Spirit Settings“ app from the Google Play.
- Go to the Settings/Wi-Fi in the Android, search for a new networks.
Native PC & Mac app
- Go to the Wi-Fi settings in the system, search for a new networks.
- Start the Spirit Settings app in the Demo mode
